Results 1 to 3 of 3
Thread: Oil Can id question
  1. Default Oil Can id question
    I found this can at an estate sale. I'm not a RR expert by far, but here is what I know about it. The owner worked for the railroad (New York, New Haven & Hartford RR) and died in 1961 at 92 years old. This can was at his son's house who just passed away at 95-moral, I think the can is pretty old, but I'm not sure how old and I'd like some help pin-pointing it a bit. I imagine cans like this were used over the course of several decades, so it might not be possible, but I figured I'd try!
    Dimensions are 31" tall and about 4.5" wide at base. Has the NYNH&HRR marking stamped on it.
    Thanks!
    The long spout indicates that it was probably used to oil moving parts on steam locomotives.
    Mark St. Aubin
    My railroad photos: http://www.flickr.com/photos/47162644@N07/
    Mar 2007
    Santa Fe Springs CA
    174
    Here's what a NH modeler had to say about this artifact:
    However it appears to be an oil can from around the 1900-25 era. I'm no
    expert on these things but just the way it looks manufactured of tin and
    the rolled metal handle that is soldered on. You can just barely see a
    seam in the can in the handle. That means it was 'rolled'and formed.
    That makes it older. Newer cans were stamped.
    Bill Shanaman
    Andy Jackson
    Bellflower CA
